I am working on an intercompany transaction where one subsidiary of the parent in buying material from a vendor which is a subsidiary of the same parent. Hence O2C-AR of the buyer should be synced with the P2P-AP of the vendor.
Buf, I am afraid that you will need to wait for PRocess Sphere ...
That being said, you can try with Process Explorer in Views.
Something like this, I guess:
BTW you can define the "contact points" between processes.
Check here: https://docs.celonis.com/en/process-explorer.html
Also you can try to model it with Network Explorer: https://docs.celonis.com/en/network-explorer-and-signal-link-explorer.html
HTH
HTH
Thanks a lot for the info @Guillermo Gost . I will try to implement it
does anyone know when this is finally coming?
Do you mean "Process Sphere", yes?
For what I understood, it is still in closed beta (in fact, my feeling is that is more an "advanced alfa" stage)
No release date AFAIK
