Full loads performed successfully but Delta loads failed?
  • November 8, 2023
  • 50 views
Forum|alt.badge.img+3
Hi expert,
I have a question regarding Delta loads. I've been using a data connection from AWS RedShift to Celonis. Before performing both the full loads and delta loads, I copy the target table, rename, and re-tied to perform Full loads and Delta loads. The full load consistently succeeds, but the delta load encounters issues.
Here's the error message for the a_size_result table:
  • Datatype of the column size_l changed from FLOAT to STRING.
  • Table won't be delta loaded. Please perform a full load instead.
When I reviewed the delta load log, I noticed that there was a change in the metadata for the 'ds_if_scm$_CELONIS_a_size_result' table.
After full loads the data, I checked the data type in RedShift (String) and the Celonis Data Pool (Varchar).
Could an expert please explain why this error occurs during delta loads?
Thanks,
Thank you for contacting us.
In order to be able to assist you further we would suggest you raise a case or send an email to servicedesk@celonis.de and provide the Data Model ID or the full URL of the Data Model.
Thank you in advance.
Valmira Abdiu
