Currently when adding dimensions/KPIs in the code editor there is a list with PQL functions and a summarized explanation of the feature.
It would be really helpful if there would be a direct link from this summary to the Celonis help documenation with usually more extensive explanations and examples.
Hi Joos,
thanks for your feature request! We are actually planning to do this, however I cannot promise when it will be ready.
David
