AWS connection from s3 to celonis. Where exactly is the window to enter the key and secret to achieve the connection (the documentation is a bit lacking)
Hmmm... probably you have tested it ... For me it seems here is clear
https://docs.celonis.com/en/aws-s3.html
Once you have finished the setup in AWS, go to the AF, select the module AWS S3 (the function you want, I picked Get File) then press in Add to define the connection and you get another pop-up where to write the Key and Secret
But, you know, I haven't yet tested it in real-life end-to-end, so it is perfectly possible I am wrong.
Hi Gost,
It seems that the specific action is not possible unless there is access to the paid account (I was using the free plan).
Sorry, but at least you got the reason... you can't fix it, but you know why it doesn't work ... 😛
That is true 😅
