Why is twice source / target not possible?
  • Feb 8, 2024 4:48 PM UTC
  • 128 views
I have calculated two KPIs. Both work and give me a result per each case. Both calculations use the source / target function and they calculate for different status the total time. When I try to substract or add the KPIs i get the following error message. I can't even use them in a chart when using the average of both. Why?
ERROR MESSAGE:
No common table could be found. The tables [<Temporary table: SOURCE/TARGET configuration _CEL_SF_ACTIVITIES,REMAP_VALUES ( "_CEL_SF_ACTIVITIES"."ACTIVITY_EN" , [ 'Set Status to Information Received - Email' , 'Set Status to Information Received - Email' ] , [ 'Set Status to Awaiting Customer Information' , 'Set Status to Awaiting Customer Information' ] , NULL ),ANY_OCCURRENCE [ ] TO ANY_OCCURRENCE [ ]>] and [<Temporary table: SOURCE/TARGET configuration _CEL_SF_ACTIVITIES,REMAP_VALUES ( "_CEL_SF_ACTIVITIES"."ACTIVITY_EN" , [ 'Set Status to In Progress' , 'Set Status to In Progress' ] , [ 'Set Status to Resolved' , 'Set Status to Resolved' ] , NULL ),ANY_OCCURRENCE [ ] TO ANY_OCCURRENCE [ ]>] are connected, but have no common table. This means that they do not have a direct (or indirect) 1:N or N:1 relationship. Join path: [Temporary table: SOURCE/TARGET configuration _CEL_SF_ACTIVITIES,REMAP_VALUES ( "_CEL_SF_ACTIVITIES"."ACTIVITY_EN" , [ 'Set Status to Information Received - Email' , 'Set Status to Information Received - Email' ] , [ 'Set Status to Awaiting Customer Information' , 'Set Status to Awaiting Customer Information' ] , NULL ),ANY_OCCURRENCE [ ] TO ANY_OCCURRENCE [ ]]N <-- 1![_CEL_SF_Case]!1 --> N[Temporary table: SOURCE/TARGET configuration _CEL_SF_ACTIVITIES,REMAP_VALUES ( "_CEL_SF_ACTIVITIES"."ACTIVITY_EN" , [ 'Set Status to In Progress' , 'Set Status to In Progress' ] , [ 'Set Status to Resolved' , 'Set Status to Resolved' ] , NULL ),ANY_OCCURRENCE [ ] TO ANY_OCCURRENCE [ ]]. For more information on the join path, search for "Join functionality" in PQL documentation.
Forum|alt.badge.img+28
Hi Cristian,
The Source/Target table create an invisible temporal table. In your example two of these tables will be created, but these are not linked to each other (and will never be, since you won't see them in the data model).
I'm not totally sure what your PQL statement is, but with a bit reverse engineering, I think you would have two options:
I hope one of this solutions works!
