What does FILTER DOMAIN do ?
  • Oct 11, 2021 3:57 PM UTC
  • 6 replies
  • 108 views
My predecessor uses FILTER DOMAIN under load script to filter the whole analysis. I couldn't find any documentation for this function. Does anyone know were I can more information ton this topic?
Thank you
bart.mient
Level 1
  • Level 1
  • Oct 11, 2021 9:43 PM UTC
Hi Sasa, I can't help with with how the FILTER DOMAIN actually behaves, but can help you with replicating this (and probably also give possible explanation on how your predecessor generated this).
1) Make sure you have some kind of filter applied in one of your use cases.
2) right-click any empty space (no component)
3) Select 'generate documentation (HTML)
4) Go down to to 'selections' all the way at the bottom
5) You will notice the applied filters have been converted to PQL that starts with FILTER DOMAIN
6) This is a bit of workaround one can use to get around writing code.
Hope this is somewhat helpful to you.
Forum|alt.badge.img+12
Hi @sasa.redze12
I have also not come across FILTER DOMAIN function documentation as such.
But from DOMAIN_TABLE function we can relate it.
The DOMAIN_TABLE  function can be used to create a temporary table from various column(s), which can be used as a target table inside all PU-functions.
Likewise FILTER DOMAIN should work.
Sharing few links which may help you in getting some idea about FILTER related function.
https://rohit-kumar103-infosys-com.training.celonis.cloud/help/display/CIBC/FILTER
https://rohit-kumar103-infosys-com.training.celonis.cloud/help/display/CIBC/DOMAIN_TABLE
Hope it helps.
Happy Learning.
  • Oct 12, 2021 8:03 AM UTC
Hi Bart,
thank you for your comment and your help.
The export function seems very helpful. I see now your point 5, how PU functions get converted. But this raises new questions.
Are load scripts entries also part of the HTML export selections section?
Load scripts, selects only cases where Vertriebsgesellschaft is '1000 - Some GmbH'
"FILTER DOMAIN "VBAK"."VKORG" || ' - ' || "VBAK"."VKORG_TEXT" AS "Vertriebsgesellschaft" IN ( '1000 - Some GmbH'
); "But the HTML export selections section is empty.
Does that mean that the load scripts filter is not active?
Hi Bart,
Hi @sasa.redze12
So answer to your query.
So the answer is yes.
Load scripts is part of sheet filter.
Error
You can find that 'sheet Filter' detail in the HTML documentation itself.
Hope it helps.
  • Oct 12, 2021 8:59 AM UTC
Hi Bart,
It doesn't seem to be in my case. Could someone verify this?
gabriel.okaba11
Depends which version are you using, but
FILTER is a general command that supports complex filter statements.
FILTER DOMAIN only supports simple filter statements with one column which is compared to constants.
•FILTER DOMAIN has been optimized for the simple statements, making it much more efficient than FILTER.
FILTER "VBAP"."TS_ERDAT" BETWEEN {t 1514937600000} AND {t 1556575199999};
FILTER DOMAIN "VBAP"."TS_ERDAT" BETWEEN {t 1514937600000} AND {t 1556575199999};
This change improves the filter evaluation performance by an order of magnitude.
In engine release 2.2 (cloud, CPM4 4.6+), FILTER automatically takes the efficient
implementation of FILTER DOMAIN if applicable
