What do the "dataSources" within YAML refer to?
  • Jun 21, 2024 1:44 PM UTC
  • 113 views
phil.cook
Level 3
I had removed ALL instances of KPI("3_days_") KPI("1_to_days_") and KPI("0_days_") from the view...but they still show up as if they exist in my Vendor LINK Scorecard table.
     name: Vendor LINK Scorecard
      options:
       density: compact
       resizeMode: expand
       allowDataExport: true
      dataSources:
      - id: 8e94d967-cd94-40a2-b167-34a913ae69fa
        pql: TABLE("contract_item_link"."LINKHDR - Vendor Org",
         PU_LAST("contract_item_link",LTRIM("contract_item_load"."YYSUPNR",'0'),
         ORDER BY "contract_item_load"."YYSUPNR"),
         PU_LAST("contract_item_link","contract_item_load"."NAME1", ORDER
         KPI("contract_item_score_link"), KPI("3_days"), KPI("3_days_"),
         KPI("1_to_2_days"), KPI("1_to_2_days_"), KPI("0_days"),
         KPI("0_days_"));
abhishek.chatu14
I am not sure of the what it means, but lest say in case you want to add a pql formula directly to youe views you need to put it in the following format
  dataSources:
    - pql:
      displayName:
      id:
phil.cook
Level 3
  • Level 3
  • Jun 27, 2024 2:54 PM UTC
Hi Abhishek.
Thanks for the response. I can understand why the values would be there...if I was still using those KPIs. But since I deleted all instances of KPI(3_days_") throughout the View whether they were in a table, graph, selection box, etc, I would think that YAML would have no references to KPI(3_days_"). Unfortunately, YAML still has them in this block of dataSources
