We are trying to add same KPIs but with different filters on same column chart (side by side), but not able to do.
  • Apr 4, 2022 12:09 PM UTC
  • 42 views
Forum|alt.badge.img+9
For e.g. we want to show number of emergency breakdowns for two plants, this will require to calculate same KPI but using a filter.
Another example is to calculate downtime for two different type of work orders ( Emergency and Preventive maintenance). We want to show comparison in same chart with two columns.
Hi @anoop.singh.rajpu , for what I understand you could create a CASE WHEN specifying which plant you're referring to.
e.g.:
CASE WHEN condition THEN 'Plant A' WHEN condition THEN 'Plant B' ELSE NULL END (In the dimension field)
In the condition specify how you recognise in the table plant A and B. At this point add the KPI, you should see how it differs per plant.
