Task Mining Screenshots
  • May 30, 2022 12:24 AM UTC
  • 146 views
After TM installation and data capture (including screenshots) I tried to visualize the Screenshots and follow all the steps for the configuration but screenshots arent apearing.,screenshots
Best answer by ömer.petek
I suppose you should open a support ticket. Celonis error returns are not enough though
  • Level 7
  • Answer
  • May 31, 2022 8:07 AM UTC
Thanks! I´ll do that!
