Something went wrong with component filter
  • Aug 6, 2022 5:23 AM UTC
  • 104 views
Hi, all
I have a button dropdown with settings: load entries, write to variable 'a'. I want to use this to do a dynamic analysis with a table. I set the component filter of the table as below:
FILTER "table"."column" = <%=a%>
But it doesn't work and give me an error message about this component filter.
I am thinking if i have overlooked any settings of component filters...
Anyone who has used component filter before and have any idea about this issue would be more than appreciated.
Thank you in advance.
I think it could be resolved by setting the Button Dropdown with a Manual Input instead of a Load entries
Then, you choose Set Variable in 'Button action', your variable and the dimension wanted in 'Set Value'
About the component, you just have to write <%=a%> in the code editor of the dimension
Does this solution resolve your problem ?
Best regards
