Removing an activity from an analysis
  • Aug 3, 2021 2:19 PM UTC
  • 104 views
Forum|alt.badge.img+7
Hi!! I'm interested in filtering an activity out of an analysis. When I try to filter out the activity from the attribute selection, the activity still shows in the Process Explorer. Is there a way to do a crop selection type filter in the load script?
Best answer by remington.roger11
Hi @remington.roger11,
What you can do to remove it from the process or variant explorer, is to use the 'Custom Dimension' field, and enter the REMAP_VALUES function:
REMAP_VALUES ( "_CEL_P2P_ACTIVITIES"."ACTIVITY_EN" , [ 'CREATE PURCHASE ORDER' , NULL ])
Unfortunately, this function cannot be used in the Load Script section (as far as I know), but in combination with the method you mentioned in your question, the activity is no longer visible in the analysis.
Cheers,
Great suggestion, I will give this a try!!! Thank you
Forum|alt.badge.img+27
Cheers,
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Aug 5, 2021 1:06 PM UTC
Indeed. I have found that the load script filters cases, but the process explorer will always show all activities (and connections) from these cases.
If you want to filter out activities you need to specify a custom dimension to return NULL for the activities you want out.
Cheers,
