Problems with the escape character ("\\")
  • Apr 7, 2022 9:34 AM UTC
  • 124 views
Celonis doesn't seem to like the escape character ("\\") when filtering graphs for product texts so tried to just replace it with the following formular:
REPLACE("VBAP"."MATNR_TEXT",'\\', '-')
However, I get the attached error message.
Best regards
Aram
Hi @aram.w,
According to the docs, you can escape spacial characters using a backslash itself. You could try in this case:
REPLACE("VBAP"."MATNR_TEXT",'\\\\', '-')
For more information, please see the help page: https://help.celonis.cloud/help/x/AgLP
Cheers,
Forum|alt.badge.img+28
Hi @aram.w,
Cheers,
