Problems with Parquet files and data types (Datetime)
  • May 5, 2023 12:24 PM UTC
  • 319 views
Working with a dataframe activity table in Python I export the file in parquet format for efficiency reasons. However, when I load the file in Celonis it doesn't recognise the timestamp in the proper format but as a string. Can anyone tell me why this error is happening?
Thank you very much.
Thanks a lot.
Best answer by badrinath.nooka13
You need to use engine, use_deprecated_int96_timestamps. in convertion to parquet file for celonis to recognize the timestamps.
Example:
df.to_parquet('data.parquet',index = None,engine='pyarrow',use_deprecated_int96_timestamps=True)
Hope this solves your issue
badrinath.nooka13
Level 4
Forum|alt.badge.img+14
Example:
  • May 5, 2023 4:46 PM UTC
Problem solved. Thank you very much.
Thanks a lot. 😄 ✌️
florian.mrkvi
Level 7
Forum|alt.badge.img+3
2 years later and this is still the only way to load timestamps correctly into Vertica.
Thank you for the hint! 🙂
