Hi everyone,
With the latest views in Celonis, is there a way to filter multiple values across one or more dimensions in one go?
For example, I want to filter all the purchase orders where field vendor name contain any of the following: ‘zxc’,’et’,’corp’ - without having to manually select each value one by one from filter dropdowns.
Is there a more efficient way to achieve this instead of configuring
  • dropdowns to select dimensions,
  • input boxes to enter search patterns, and
  • variables?
For multiple dimensions, this setup becomes impractical.
Thanks in advance!
Be the first to reply!
