Jupiter - What are the data volume limits to be processed in the Machine Lerning Workbench?
  • Apr 19, 2022 4:14 PM UTC
  • 107 views
Are there any limit to the amount of data to be processed by a Jupiter notebook running in the Machine Learning module?
I mean... can I for example load a pandas data frame with 2 billion rows ...or any crazy volume?
Is there going to be a cost associated with execution of a Jupiter notebook? or to the data volume processed or the cpu used?
TIA!
  • Level 0
  • Apr 25, 2022 2:07 PM UTC
Dear Tia,
Thank you for reaching to us.
Please be informed that there is no limit, but kindly note that the free license would contain 1 CPU, 4GB Ram and 6 GB disk space.
So, when the queries or requests are heavy then you need dedicated resources.
In order to be able to assist you further, we would suggest to send an email to servicedesk@celonis.com with detailed description.
We will gladly try to help you.
Thank you in advance.
Dear Tia,
Thx!
(BTW name's Guillermo... TIA means 'Thanks In Advance'... old Inet lingo :D :D :D )
  • Level 0
  • Apr 25, 2022 2:15 PM UTC
Hi Guillermo,
We apologize for the misunderstanding and misinterpretation.
Thank you for your understanding and collaboration, on this matter.
Sara.
Hi Guillermo,
Sara.
No worries!👍
