Is there a way to start an Action Flow via an URL with some fields? Just like the Manual Sensor in Skills, but for Action Flows.
  • Jun 15, 2023 2:45 PM UTC
  • 5 replies
  • 194 views
That way I could put the link in the button in an Analysis, and the users could click there, fill in some fields, and done - and that would execute the Action Flow with the values of the formular.
kailash.potha12
Hi Josep,
I think you cannot directly trigger action flow but you can run ML notebook, from there you can trigger action flow.
https://docs.celonis.com/en/trigger-an-action-flow-from-ml-workbench.html
Forum|alt.badge.img+14
  • Level 8
  • Jun 16, 2023 8:44 AM UTC
Hi, you can explore webhoook in action flow.
https://docs.celonis.com/en/webhooks--action-flow-.html
Thank you,
Rio
  • Jun 16, 2023 8:54 AM UTC
Thank you,
Rio
Does not apply. If you set up a webhook than either (1) you activate it via a GET request, in which case you cannot pass any parameters, or (2) you activate it via a POST request. None of these serve the purpose of an URL that directs to a formular, where users can fill fields that are used as parameters for the execution of the Action Flow.
  • Level 8
  • Jun 16, 2023 9:04 AM UTC
Please review again. go to the section on query string parameters. We have done similar - you can pass parameters via query string. if you can construct that then this should be sufficient.
  • Jun 20, 2024 10:59 AM UTC
Hello Josep, were you able to do it? I'm looking for the same answers.
