Is there a way to extract Celonis Users Information automatically?
  • Apr 20, 2022 7:00 AM UTC
  • 85 views
Essentially, we are tracking usage of our Action Views / Skills through an augmented attributes table. Unfortunately, this table refers to users through a code (CHANGED_BY field):
CHANGED_BY - User ID
We have recently realized that we can extract User Information like this:
Getting User Info
Which will give us a correlation between User IDs and the actual Users (Name + E-mail):
My InfoSince we have an ever-shifting user-base, is there a way for us to get this information into/from Celonis' Back-End (Data Integration) automatically?
Thank you in advance!!
Forum|alt.badge.img+27
Hi @vasco.caron11,
Good question! I had the same one a while ago, but unfortunately it seems that it isn't possible for now: https://www.celopeers.com/s/question/0D50700000lPfeTCAS/extract-team-data-users-and-apc-usage-via-pycelonis
Hi @vasco.caron11,
Hello @janpeter.van.d
That is unfortunate, thank you for your answer
Vasco Carona
