Is there a way do reproduce 'logbook' on Studio?
  • May 3, 2022 1:47 PM UTC
  • 92 views
I was looking for a way to take 'pictures' to track a few KPI's through time. I used to do that with Transformation Center using the Logbook feature, but I'm a little bit lost about how to do it on Studio.
gabriel.okaba11
Hi Marco,
As a short-term solution, you can create an action flow to store the KPI values in a Google Sheet/Excel Sheet
Hi Marco,
You can also use Machine Learning.
  1. Create table in data model called "logbook" or whatever suits you best.
  2. Pull data from data model: Data Model: Pull data - PyCelonis.
  3. Push data to previously created table: Data Pool: Push data - PyCelonis
You can define KPI using pql directly in ML.
Sample below:
Regards,
Marcin
