Is it possible to get the load script filter which gives the same result as this selection? ie. process flows through 'Deputation letter generated'
  • Jan 28, 2022 3:23 PM UTC
  • 119 views
Hi everyone, I need to use load script filter for some pages in which the process has to be flow to this step 'Deputation letter generated'.
I had tried,
  1. FILTER PROCESS EQUALS '<%=activity_name%>'
  2. FILTER ISNULL(PU_LAST("Table_name",ROUND_DAY("Activity_Table"."EVENT_TIME"),"Activity_Table"."ACTIVITY"='Deputation Letter Generated')) = 0;
But it is not working.
Kindly help me to solve this please
Best answer by pablo.maced
Hello Kavitha,
As stated in help page (https://help.celonis.cloud/help/display/CIBC/Filter+Editor) FILTER PROCESS EQUALS Activity_Name' should work.
I have tested it myself on trying environment and it worked fine:
  • Without filter
process without filtering
  • Filter:
filter
  • Process Explorer with filter
Filtered PE
I recommend chacking syntax and possible spelling errors as it should work like this.
Hope this helps you.
Best regards
  • Celonaut
  • Answer
  • Feb 8, 2022 6:14 PM UTC
Hello Kavitha,
  • Without filter
  • Filter:
filter
Filtered PE
Best regards
