Inconsistent spaces in Column chart in Views
  • Jan 8, 2024 6:12 AM UTC
  • 151 views
celonis chart errorThe column chart when spit by x axis resulting in displaying booth the KPIs but the space between both bars are inconsistent throughout and also in the 4th column is the second bar stays hidden.
Can somebody help out with the solution for this?
abhishek.chatu14
The only thing I can think of is padding
Width in pixels of the white space between bars in a bar chart.
encodings:
y:
field: XYZ
padding:
ordinal: 0.1
axis:
position: left
  • Jan 8, 2024 4:35 PM UTC
Also check that there aren't NULL series being returned with the results and getting plotted with nothing but a placeholder for the label.
