I want to know the latest activity between A and B, in a process and create a filter. which PQL function i should use.
  • Apr 22, 2024 12:12 PM UTC
  • 5 replies
  • 131 views
Sverre Klein
Forum|alt.badge.img+13
Hi @Dipashree Dandsena,
I'm not quite sure what you mean by "latest activity between A and B", could you elaborate on that?
In any case, I think you are looking for ACTIVITY_LEAD, which shows the next activity in succession.
https://docs.celonis.com/en/activity_lead.html
Let me know if this is what you are looking for.
Sverre Klein
  • Apr 23, 2024 4:01 AM UTC
Hi Klein, I want to know the cases where, between activity A and B the last activity is A. I mention again a may not be the last activity of the process, its last between the two. Because if A is set block and B is remove block then i have cases where A-->B--->A-->B-->A might happen.
Sverre Klein
I see, I think you can use the CALC_CROP function. This operator crops cases to a range of activities. You can also specify ranges.
CALC_CROP (celonis.com)
Hopefully this puts you in the right track 😁
Sverre Klein
  • Apr 24, 2024 8:48 AM UTC
Hi Klein,
Thanks! i tried using that operator but not getting the required result. Any other way?
Regards,
Dipashree
Sverre Klein
Sorry to hear it didn't work for you. Could you share a screenshot of what you are currently seeing using CALC_CROP and what your desired outcome would be?
Thanks!
Sverre Klein
