I am trying to create a component filter for "the running past 24 months". - I can get a "since 2022" to work, but I can't get a floating filter, like "for the past two years" to work.Can you help me with the general syntax?Thank you.
  • Apr 23, 2024 9:04 PM UTC
  • 163 views
karl.guent
Level 6
I am trying to create a component filter for "the running past 24 months". - I can get a "since 2022" to work, but I can't get a floating filter, like "for the past two years" to work. Can you help me with the general syntax? Thank you.
Best answer by Anonymous
for the past 24 months simply use ADD_MONTHS(TODAY(),-24) in the comparison, i.e.
FILTER Table.Date >= ADD_MONTHS(TODAY(),-24)
BR
Stephanie
Sverre Klein
Forum|alt.badge.img+13
Hi @karl.guent,
Very good question, I never tried this but I got something working.
FILTER YEAR ("ACTIVITIES_TABLE_PO"."EVENT_TIME") => (YEAR(TODAY()) - 2);
Let me know if this works on your end. Please validate the results 😁
EDIT: I think it should be => rather than >, I changed this.
Sverre Klein
  • Answer
  • Apr 24, 2024 9:58 AM UTC
BR
Stephanie
karl.guent
Level 6
  • Level 6
  • Apr 24, 2024 1:38 PM UTC
Wow! These are both awesome!
  • Stephanie ... The "TODAY -24 is truly elegant.
  • Sverre ... the From => To approach is the way I was also thinking.
Sverre Klein
BR
Stephanie
Very nice, thanks Stephanie! 😊
