How to use dynamic parameter variable to store select query output?
  • Sep 22, 2021 7:18 AM UTC
  • 63 views
Hi All,
In celonis transformation I would like to use Dynamic parameter to store the select query output and the same parameter i need to use in upcoming queries for further processing.
Could you please help me with option for the same?
Thanks in Advance.
gabriel.okaba11
Hi Nanthinidevi,
Parameters allow you to define reusable pieces of information on data pool level to be reused in specific tasks using their parameters. Within the data pool, go to Data Pool Parameters on the left side and select dynamic.
You can use one of the following operations to get a dynamic value to be reused within the data jobs
FIND_MAX
FIND_MIN
LIST
