How to migrate a table using the pql.DataFrame function with dollar sign "$" in the column names.
  • Aug 14, 2023 8:47 AM UTC
  • 62 views
mathijs.lende12
Level 4
Forum|alt.badge.img+11
We want to migrate a table from a data model where the table column names have dollar signs ($) in the name. When we try to migrate the table we get a column not found error on those columns that have a dollar sign in the name. Is there a way to encode or otherwise provide the column names to the pql.DataFrame function such that it can use columns with $ signs?
Forum|alt.badge.img+5
Apologies for the inconvenience you have encountered. As you already created a support ticket regarding this issue, our Customer Support will contact you through the case. Thanks for your understanding.
