How to export data model technical document.
  • Mar 20, 2023 12:38 AM UTC
  • 467 views
Hi Expert,
Does anybody know how to export data model technical document as same as dashboard?
I just would like to share how to connecting SAP add-on table to business side but there I don't found any connection export way other than json. (business side don't know tech except SAP so I need something natural language one is better.)
Do we have something way to export data model?
Best answer by Anonymous
I don't think we have that option to export a data model. But please keep us posted when you have the answer. thanks.
  • Answer
  • Mar 22, 2023 9:34 AM UTC
  • Mar 23, 2023 7:31 AM UTC
Thanks, I noted :)
Hi Atsuya, unfortunately, it is not possible to export data models. Thank you for your understanding. Best regards, Lejla Mustafa
