How to Epoch to Date conversion in EMS using SQL or PQL?
  • Aug 14, 2023 5:05 AM UTC
  • 223 views
mallik.koruk11
Level 6
Forum|alt.badge.img+10
To explain in simple terms, how can I convert Epoch number "1691989479" to date "August 14, 2023 6:04 AM" using PQL to SQL logic?
Forum|alt.badge.img+28
Hi @mallik.koruk11,
I hope this answers your question.
Cheers,
mallik.koruk11
Level 6
It is working in PQL editor, but it is converting in the action flows configuration itself.
Thank you very much :)
Hi @mallik.koruk11,
You can try to things to solve this:
mallik.koruk11
Level 6
Its helps, thank you very much :)
