How to dynamically set a value in chart title instead of using a textbox component in view?
  • Jan 18, 2023 2:44 PM UTC
  • 148 views
I want the value to be update after every load and it has to be dynamic.
I can consider the value field in textbox component.
But I’m trying to figure out if this can be done in chart title itself in a view
abhishek.chatu14
Hi Preethi,
The only way I think you can have this is if a variable is able to store the value i.e runtime variable or view variable.
PS: I think you have already implemented the solution i.e using the textbox component, however you can explore the variable option. Not sure if its possible to update the variable values based on every load.
  • Jan 23, 2023 6:31 AM UTC
Hi Preethi,
Thank you @Abhishek Chaturvedi
yes, I tried both variable and textbox thing
Even I’m trying to figure out if there is a way to update the variable on every delta load
Hi Preethi,
Could you please open a ServiceDesk ticket ? They'll be able to help you out.
Many thanks,
Mentor
