How to convert string(format YYYYMMDDHHMMSS) into the timestamp(date) value using either SQL or PQL?
  • Sep 9, 2022 6:49 PM UTC
  • 237 views
deepak.kumar30
Level 3
  • Sep 10, 2022 7:27 AM UTC
Hey Deepak,
In Celonis you can use the TO_DATE function (https://docs.celonis.com/en/to_date.html).
For the current time this would result in:
TO_DATE ( '20220910092700', FORMAT ( '%Y%m%d%H%M%S' ) )
This should work.
Maurits
  • Nov 11, 2022 11:13 AM UTC
Getting syntax error
Output
Execution error: Incorrect syntax near '20220910092700'.
  • Feb 15, 2023 10:29 AM UTC
Hey Anad,
Above synthax works in the cloud environment. Could you provide the full formula you are using?
Synthax and output
