How to add a conditional filter to a component filter (load script)?
  • Feb 16, 2023 11:09 AM UTC
  • 223 views
milan.eric
Level 6
Hello everyone,
I am writing here because I couldn´t solve my issue with other questions asked.
My Situation:
I have an OLAP-Table with a lot of Data and dates regarding finances.
Now I want to add an Input Variable where User can input a single date.
Depending on that input, the OLAP-Table should change (2 columns)
The field is OPTIONAL and I am struggling with handling the case of "null" as input.
My current idea:
FILTER "Table"."SomeDate" >=
CASE WHEN <%=DATE_OPEN_ITEMS%> is not NULL
      THEN TO_DATE( <%=DATE_OPEN_ITEMS%>, FORMAT ( '%d-%m-%Y' ) )
     ELSE ignore the filter all together
Now if I type in '31-12-2022' it works great!
But 1. If the input field is empty there is an error
and 2. the User has to use ' ' while typing it in.
Any ideas?
Thanks!
Hi Milan,
The simplest solution that might work would be to create a Saved Formula (in Analysis)/ KPI (in Knowledge Model) that wraps your variable in between brackets.
Saved Formula to wrap variable between brackets
milan.eric
Level 6
  • Level 6
  • Feb 16, 2023 1:20 PM UTC
I managed to do it like this:
FILTER
((ISNULL(<%=DATE_OPEN_ITEMS%>)=0) AND "Table"."SomeDate" >= TO_DATE( <%=DATE_OPEN_ITEMS%>, FORMAT ( '%Y-%m-%d' ) ) AND "Table"."SomeDate" <= TO_DATE ( <%=DATE_OPEN_ITEMS%> , FORMAT ( '%Y-%m-%d' ) ))
OR
(<%=DATE_OPEN_ITEMS%> = ' ') AND "Table"."SomeDate" >= TO_DATE( '1900-01-01', FORMAT ( '%Y-%m-%d' ) ) AND "Table"."SomeDate" <= TO_DATE( '2999-12-31', FORMAT ( '%Y-%m-%d' ) )
Problem 2) persists. The User has to type in ' ' for it to be "Null" and every date has to be in apostrophes. Not sure how to fix that.
Any help?
Forum|alt.badge.img+28
Hi Milan,
milan.eric
Level 6
  • Level 6
  • Feb 16, 2023 2:08 PM UTC
Hi Milan,
Thank you so much! That actually worked! I only used Variables and never thought about this. So simple yet so hard.
Haha, cool! Glad that it helps you.
