How does the workday calendar in data model look like?
  • Jan 27, 2022 1:25 PM UTC
  • 10 replies
  • 287 views
Dear Community,
we would like to use the workday calendar feature in the data model, so that we can calculate the lead time excluding all public holidays + weekend.
Since our data source is not based on SAP, we don't have the TFACS-Table. Can someone help and tell me what kind of table I should update here as a workday calendar:
  • which columns are mandatary?
  • how should the table look like?
  • what is the corresponding data format?
An example table would be very helpful here.
Capture
Thank you in advance.
Liz
  • Jan 27, 2022 2:47 PM UTC
Hello Liz,
Here you can find how original, standard TFACS SAP table looks like:
https://www.se80.co.uk/saptables/t/tfac/tfacs.htm
MON01(02, 03, 0N) are just filled with 01010101 values:
TFACSHere you can see additional examples:
<you_celonis_link>/help/display/CIBC/WORKDAY_CALENDAR
Mateusz Dudek
  • Jan 27, 2022 4:19 PM UTC
Hello Liz,
Mateusz Dudek
Hi Mateusz, Thanks for the quick reply. It helps.
One more question, have I understood correctly? If I use the workday option, the calculation of lead time will only skip the date when it is set to 0 in the calendar.
Is it possible to add working hours, similar to the weekday calendar? For example, 1.1 will be skipped due to public holiday. The working hour on 1.2 is 9-18. So only the lead time between 9-18 will be taken into account.
Liz
  • Jan 27, 2022 5:23 PM UTC
Hello Liz,
Mateusz Dudek
Hi Mateusz,
I have tried to create the table manually and uploaded it. Somehow it cannot be recognized.
imageMy table looks like this. Could you help here? Thanks!
imageBest Regards,
Liz
  • Jan 27, 2022 5:40 PM UTC
Hello Liz,
Hard to tell, I will make some tests in my spare time, and check what's the difference between real TFCAS SAP table and the example ones in the Celonis documentation.
For now, the reason can be that each value has ' character at the start and the end. Table from sap doesn't have such additional characters. Try to remove that, and also upload file as "CSV UTF-8(Comma delimited) (*.csv)" filetype.
However if you only want to exclude some days (for example weekend) in calculation you can use weekday calendar, or weekday formula, as it may be easier. The function should produce the calendar in the celonis itself based on selected days).
weekday <your_celonis_link>/help/display/CIBC/WEEKDAY_CALENDAR
Mateusz Dudek
  • Jan 27, 2022 7:49 PM UTC
Hello Liz,
Mateusz Dudek
Hi Mateusz,
I have also tried the csv version without quote. It is also not working. I have attached my test.csv.
Thanks,
Liz
  • Jan 27, 2022 11:15 PM UTC
Hi Mateusz,
Thanks,
Liz
It seems last 4 columns were missing, I've tried and the file seems to be accepted.
Try with that one:
TFACS corr
Mateusz Dudek
  • Jan 28, 2022 10:16 PM UTC
Hi Mateusz,
Thanks,
Liz
Hi Mateusz, thanks for the corrected file. It works in our sandbox. The problem seems to be our prod-environment then. I need to investigate more.
Liz
Hi everyone, I found this post extremely useful but I'm having some difficulties trying to get my TFACS calendar loaded into Celonis properly and being detected in the analysis.
I have followed similar to what is being mentioned above in terms of the schema and format but Celonis was not able to detect it as a possible workday calendar:
imageAttached is a sample data created:
Update: We were able to resolve it. The formatting in the above is correct. Just need to refresh and load the data model along with the case + activity table. Also in the above file, the Feb data is incorrect (only has 20 data points, where it needs to need to have 28 data points for year 2023) 😁
dxb.miner
Level 5
  • Level 5
  • Nov 13, 2024 1:28 PM UTC
TFACS_table: The name of the TFACS table in the data model. Must have at least the following attributes
  • IDENT: STRING column containing the TFACS entry identifier (e.g., to refer to a location-specific calendar).
  • JAHR: INT column containing the respective years covered by the TFACS table entries.
  • MON[01-12]: STRING columns containing the respective bit encoded days for each month (1: working day, 0: non-working day).
