How do you convert date column from string to datetime at the extraction stage? I tried configuring the column but keep receiving an error.
  • Dec 15, 2022 10:09 AM UTC
  • 150 views
teuku.faruq13
Level 9
Hello @william.ross12 , do you still have issue? May I have your sample input? Celonis is based on SQL Reference (vertica.com)
  • Dec 16, 2022 7:00 AM UTC
  • Dec 21, 2022 8:06 PM UTC
Just small note, Celonis uses 10.1.0 Vertica version, but in most function there's no difference.
Would go the same direction on extracting string, and then creating table with real timestamp using that function. @Guillermo Gost post may be marked as best.
Mateusz Dudek
  • Feb 15, 2023 4:11 PM UTC
Mateusz Dudek
Thank you that's really helpful! Apologies for late reply
