Top Header
How do I keep the denominator in my Calculation constant (so that it doesnt change when I filter on it for different dates)
bennita.dutoi12
Level 4
KPI("cancelled_cases")*(KPI("cost_per_transaction"))
The Cost per transaction should stay the same figure:
Cost per transaction: KPI("total_operating_costs")/Global(KPI("case_count"))
So the Case count above must stay the total amount of cases and not reduce if I filter for a shorter time. The Total operating cost is a constant figure.
mateusz.dudek14
Level 7
Forum|alt.badge.img+11
Maybe create KM variable, that will be updated on the daily basis? Then as It's not connected to any table in DM, shouldn't be affected by the filtering?
Mateusz Dudek
bennita.dutoi12
Level 4
mateusz.dudek14 wrote:
Mateusz Dudek
thanks Mateusz, I tried the following now that seems to work
KPI("total_operating_costs") /  PU_COUNT ( CONSTANT ( ) , ${{case_tbl_casekey}} )
