How do I create a Stacked Chart in old views?
  • Jun 14, 2024 11:32 AM UTC
  • 170 views
bennita.dutoi12
Level 7
I would like to have the green start where the blue stop (Stacked graph)- how can I do that?
matt.witty13
imageIn your YAML, you'll want to code in the field "stack:" and then list the KPIs you want to stack.
Pretty sure you can also use the "Stack By" parameter in the Visual Editor:
imageI find using the YAML better so you can have more control over what it looks like.
bennita.dutoi12
Level 7
Thanks a million Matt - it works!
