How can I show the ratio after applying a specific filter?
  • Aug 11, 2022 6:53 AM UTC
  • 166 views
スクリーンショット 2022-08-11 15.50.25Hi community,
I would like to create OLAP table which is shown in the attached pic.
The table includes kinds of fruits, amount, and ratio.
[QUestions]
How can I calculate the ratio after applying a specific filter?
[tried]
  • Using SUM(filter to null(amount))
Thank you for your support!
  • Aug 11, 2022 3:29 PM UTC
Maybe the filter can write to a variable? You could set up a variable for "Fruits". When you select values from the drop down, the filter variable is set to those values. Then your ratio can be the amount of each fruit as a percentage of "Fruits" variable?
You could potentially do something similar as a component filter or sheet filter.
  • Aug 12, 2022 2:49 PM UTC
Hi Sean!
Thank you for your answer!
I tried to set up a variable for Fruits and made it a filter.
But, it doesn't work...
The ratio does not show correctly.
*it shows 100%
Here is my setting for a dashboard.
[variable]
variable X = fruits
[filter]
fruits(variable X) as dropdown
[formula for calculating ratio]
SUM(Amount) / SUM(Amount)
[columns for OLAP TABLE]
fruits, Amount, ratio
  • Aug 17, 2022 1:40 PM UTC
I don't think that this is possible. You can make a new table column with the old_ratio and maybe attach it to the new table. But I don't think that this works only with PQL-Statements in the environment.
