How can I build a Concur Connection?
  • Feb 13, 2023 9:30 AM UTC
  • 5 replies
  • 264 views
Dear Celopeer
Hi.
I would like to build a Concur Connection and extract data via the Concur API, but I couldn't find a Concur Connector (I think there used to be one, as described in this document SAP Concur Connection [Extractor Builder] (celonis.com)).
imageDoes anyone know how to connect to Concur via API?
Best answer by Anonymous
I am also just now in the process of connecting with Concur.
Is it possible to do the following steps?
1.Scroll down the screen and select "Build Custom connection" -> "Customize a Celonis Extractor".
2.Select "Concur”
1.
image2.
  • Answer
  • Mar 10, 2023 1:51 AM UTC
2.Select "Concur”
1.
image2.
  • Mar 10, 2023 4:17 AM UTC
Dear Enomoto-san
Thank you! I also just found that Celonis has launched Concur connection. Hope it works well.
  • Mar 10, 2023 4:34 AM UTC
Dear Enomoto-san
It was good to be of help.
I hope that your work goes well.
  • Level 0
  • Mar 10, 2023 7:07 AM UTC
Hi, please let us know if there is any action required from support at this point. Best regards, Pablo
  • Apr 3, 2023 7:25 AM UTC
Hi, Pablo.
I too have a question about the "Concur" connection.
The "Concur" connector in "Customizable Extractors" seems to get data for "Concur Expense".
I would like to run the "Invoice" and "Request" data retrieval API, do you have a sample?
Masaki
