How can I apply a conditional format color scale, based on the minimum and maximum values of an OLAP table that has aggregations like COUNT and SUM to calculate its values (similar to what is done by Excel)?
  • Apr 25, 2022 6:37 PM UTC
  • 96 views
leonor.doris.rodri
Level 3
Conditional format exampleI've tried the background color mapping, but the options are specific values and not the minimum/maximum depending on the calculation of the table
Thanks
Dear Leonor, Many thanks for reaching out and accept our sincere apologies for the delayed response. We would suggest checking the following help article https://help.celonis.cloud/help/display/CIBC/Charts+and+tables+-+Settings where it is described how to achieve the coloring feature in Celonis. Thank you for your patience. Best regards, Valmira Abdiu
