Histogram with a KPI
  • Apr 17, 2023 10:38 AM UTC
  • 155 views
Hi, i am looking to build a histogram in a view with a KPI which gives a throughput time between 2 activities. I need the frequency of cases on Y axis, and a (automatic) grouping/bucketing of the KPI values on the x axis.
I have tried to use the Histogram option in the View, but it seems not to accept KPI's (only data value columns). So i created a Record (attribute) in the activity table with the same formula as the KPI and use that as attribute in Histogram instead. But i get an Error: "Aggregate expressions cannot be nested inside aggregate expressions."
Is there any other way of producing the desired result? I can use a normal chart but it will not do the buckting automatically and i don't know how or where to create an extra buckting table.
Thanks in advance
Himanshu
  • Level 0
  • Jul 8, 2023 10:50 PM UTC
Hi Himanshu,
Please find here our documentation for Histogram configuration:
https://docs.celonis.com/en/histogram.html
If you have further questions or issues please raise a support ticket in Celopeers and we will get back to you.
Many thanks,
