Hi, The input I insert in my input box disappears once I leave the page. What could I be missing?
  • Apr 29, 2024 11:45 AM UTC
  • 120 views
bennita.dutoi12
Level 7
Here is my YAML code
type: input-box
settings:
  type: number
  onChange:
    update:
      variables:
        - name: FTE_cost
Sverre Klein
Forum|alt.badge.img+13
Hi @bennita.dutoi12,
I took this for the Celonis documentation. https://docs.celonis.com/en/input-box.html
I think the placeholdertext key can help to have an example of the input text for the user. Is this what you mean?
- id: input-box
 type: input-box
 settings:
   styles:
     position:
       horizontal: right
       vertical: bottom
   placeholderText: Type your text here
   type: string
   onChange:
     update:
       variables:
         - name: textinput
Sverre Klein
bennita.dutoi12
Level 7
- id: input-box
 type: input-box
 settings:
   styles:
     position:
       horizontal: right
       vertical: bottom
   type: string
   onChange:
     update:
       variables:
         - name: textinput
Sverre Klein
thanks Sverre, unfortunately it also doesn't work - the text that is then inserted still disappears once I leave the page.
Sverre Klein
Alright, that is odd, could you provide some screenshots (or video) of what is happening? Are you for instance saving your changes when you leave the page?
bennita.dutoi12
Level 7
Apologies Sverre, your solution did work, i applied it wrong the first time. thank you so much
