Hi Team, is there any way to execute the Celonis data model from Action Flow.
  • Mar 12, 2023 2:06 PM UTC
  • 99 views
anusuya.ponnu
Level 3
I need to check for a value (eg. 'COMPLETED') of a table column from Celonis transformation. The action flow needs to check for the status of the column like every 15 minutes and once it finds the 'COMPLETED' status, the Celonis action module needs to execute the corresponding data model. Appreciate the ideas/logic.
Forum|alt.badge.img+14
  • Level 8
  • Mar 13, 2023 12:20 PM UTC
Hi, you can use the HTTP module and call the API to execute data model reload.
https://docs.celonis.com/en/process-data-model-api.html
