Hi Team, I am facing below error while making connection through Extractor Builder:"Connection test failed, please check the Data Connection's configuration and ensure that the system is running: Connection configuration invalid"
  • Jul 17, 2024 9:17 AM UTC
  • 249 views
Hi All,
This is the detailed explanation regarding what Information I have, what steps and option I followed to make this connection:
Steps followed:
Add Data connection-->Connect to Data Source-->custom-->Build Custom Connection-->Build a new extractor:
(1) Extractor Information: Input provided in the Name filed
(2)Connection Parameters: Unchanged
(3)Authentication Methods: API Key Authentication Selected and In the API Key header: Key generated from admin setting was entered .e.g. x-api-key:"Generated Key".
(4)Define Endpoints: Add new endpoint-->
(A)Configure Endpoint:
Endpoint name(entered)-->HTTP Method(GET)-->Use this endpoint for connection test(enabled)
(B)Configure Request
URL: {Connection.API_URL}/"Endpoint URL entered"
Request Parameters: Leaved as it is
Headers-->Add new header-->"Key and Value" entered
Pagination Method: Leaved as it is
(C)Configure Response: Leaved as it is
Clicked Fininshed.
