Hi Guys,i get the following error when using the PU_Max pql expression:"Syntax error near [PU_MAX] after reading [] at line 1. " The Expression is:" PU_MAX ( "_CEL_AP_ACTIVITIES","AP_BSEG"."ZTERM", [COUNT] );"
  • Jun 8, 2022 10:53 AM UTC
  • 130 views
Where is the Problem in my expression and where can i find documentation that isn't blocked by Celonis firewall? When i try to open the celonis. help website i get blocked by the firewall no matter from what and where i try to access the website. Every help is much appreciated, thank you!
Best answer by attila.cserv11
Hi Phillipp,
  1. check this until Help is recovered: https://docs.celonis.com/en/pql---process-query-language/pql-function-library/aggregation/pull-up-aggregation/pu_max.html
  2. ",[COUNT]" must be the issue, the 3rd parameter of the PU function must be a filter, but this ",[COUNT]" cannot be interpreted as a filter.
  3. PU function works on tables in 1:N relationship. 1st parameter table must be the "1" and the 2nd paramater must be the "N" table. But in your expression this is in the other way round: in the AP data model the Activities table is in "N" role and AP_BSEG table is the case table in "1" role.
Best, Attila
attila.cserv11
Level 3
Forum|alt.badge.img+16
Hi Phillipp,
Best, Attila
