Help with Input Box to modify Variable
  • Mar 27, 2023 11:14 PM UTC
  • 160 views
I have created variables in my Knowledge Model (see YAML below) that I am trying to have input boxes to modify. On my View, when I create an Input Box and try name a variable I get an error that no variables exist. What am I doing wrong?
Bonus Question: In Views can I use those variables to create an Improvement Opportunity calculation similar to that of Analysis?
Knowledge Model Variable Definition:
variables:
  - id: input_me
    displayName: Input
    value: |
      5
*note I did not think I had to define a value, but I am required to in the visual editor
YAML for the Input Box:
type: input-box
settings:
  type: number
  onChange:
    update:
      variables:
        - name: <Input>
[note the error at the bottom of the screen says that no variables are available]
  • Mar 28, 2023 9:32 AM UTC
For sure you can use runtime variable which will be accessible in both View and Knowledge Model. You can read about it here:
Package runtime Variables (celonis.com)
Maybe there is a different way but to be honest I am not aware of it
Good luck :)
Forum|alt.badge.img+28
Hi Timothy,
To make things simple, there are multiple types of variables, all with their different use cases:
  • runtime variables: use through the entire package (see example of Marcin above, Package runtime Variables (celonis.com))
  • view variables: use within views to change behaviour of the analysis, this elements will directly be updated (for instance, change chart dimension from months to quarters, Views Variables (celonis.com))
  • Knowledge Model variables: To use within the knowledge model itself, cannot be used within the views nor analyses, but only within KM KPIs/Filters (see Knowledge Model - Variables (celonis.com)).
  • Analysis variables: Can only be seen within Studio Analyses, mainly the same functionality as KM variables, but on a different place.
To see the variables that you can access within a view, press the variables button on top:
