Hello, we have an application that calls Celonis from outside of Celonis. On the 1st call within 7 or so minutes, Celonis returns the data in about 13 seconds while subsequent calls take 2 seconds.
  • Feb 22, 2024 5:04 PM UTC
  • 8 replies
  • 192 views
It seems that the 7 minute window is related with connection session or its equivalent? Are we able to increase this period and if so where is it set? Or is the 7 minute window related with something else? What options do we have?
Sverre Klein
Forum|alt.badge.img+13
Hi @milan.demel,
For some additional information:
  • What application are you using
  • What is the nature of the call that you are using? What is it that you are retrieving from Celonis?
Sverre Klein
  • Feb 26, 2024 1:36 PM UTC
Hi @sverre.klein11, here are your answers:
  • A small internal application we developed for our team
  • Employee specifies a record ID and the application returns the status of that record
It is a very simple request, response app and we just want to know if we can increase the connection session (I assume that is what that is) so that the response takes 2 seconds instead of 13.
Regards
Milan Demel
Sverre Klein
Hi @milan.demel,
Thanks! So for my understanding:
  • The first call to get a record ID and the status takes 7 minutes
  • The second call 13 seconds
  • The subsequent calls 2 seconds.
Do you have any (trace) logs of the execution of the connection? It's hard to debug this issue without any logs or something like that.
Sverre Klein
  • Feb 26, 2024 1:57 PM UTC
Hi @milan.demel,
Sverre Klein
It is like this @sverre.klein11 :
  • 1st call 13 seconds
  • Additional calls 2 seconds
  • It all resets if no calls placed for around 7 minutes
So session time out seems to be those 7 minutes. Can we increase this time?
Sverre Klein
Hi @milan.demel,
There is an option in Celonis itself to enable the Session Timeout. I'm not sure if this will work though, never tried it.
  • Feb 27, 2024 10:37 AM UTC
Hi @sverre.klein11 , we checked this setting and it is disabled defaulting to 20 minute session time out. So this is not a solution and the setting is somewhere else.
To summarize, if we continuously make calls to Celonis within 7 minutes, they always come back within 2 seconds. Only if we call Celonis after 7 minutes or the 1st time, it takes 13 seconds to get an answer from Celonis.
We want to increase this 7 minute window to perhaps 20 minutes so that we always get Celonis result in 2 seconds. Is there perhaps an API session setting somewhere?
Thank you
Milan Demel
Sverre Klein
Thank you
Milan Demel
Hi @milan.demel,
Sadly I don't know that 😶, apologies. I would advise you to contact Celonis support to see if they can help you with that. Flow (celopeers.com)
Sverre
  • Feb 27, 2024 1:26 PM UTC
Thank you @sverre.klein11 for trying and identifying the actual Celonis application timeout-setting, that was useful. Appreciate your support
Regards
Milan Demel
