Good day,
When I get an error message in my transformation “error at character 28152”, how do I find character 28152?
Thank you,
Good day,
Thank you,
This is a tricky one its per character count and the count I believe starts from 184
Here comma is the issue i.e. 184+10 = 194
You have to count each character
Notepad++ : Provides a feature to go to a specific line or character position by pressing Ctrl + G
. You can input the character position to jump to that part of the text.
So in my case I would have done the 194 - 184 = 10 and then used Notepad++
Hope this helps !
Thank you, I will try this!
