EBAN Data Model - Set Up Error
  • Jan 24, 2024 4:07 PM UTC
  • 101 views
julia.bauer
Level 9
Hello everyone, I'm trying to set up a new DM as the P2P Data model (with join EKPO and EBAN) only makes requisition numbers visible that were already converted into an order. With a separate DM I only want to see the requisition numbers that are open and not processed yet (with some other filters from other tables). Does anyone of you already set up such a data model? I'm currently getting this error message and I have already all the keys that should provide distinct data rows.
Thanks so much!
BR
Julia Bauer
Error MessageDM Setup and tables needed
Hello Julia,
it looks as if there are some joins in you transformations that are creating duplicates. The error message you provided alreasy gives you a hint where to look at.
You could try the following query to understand where the duplicates are coming from:
SELECT A, B, C, D, E, F, COUNT(A) FROM X
GROUP BY 1, 2, 3, 4, 5, 6
ORDER BY 7 DESC
where X is your table (for the first issue 'EBAN') and A-F are the respective columns.
This might give you some indication as to where to find the issue.
Unfortunately, if this doesn't work you would need to raise a ticket for someone to have a more precise look at your environment.
Bernardo
