Data Transfer between Sand Box Environment to Prod Environment
  • Apr 8, 2024 6:02 AM UTC
  • 5 replies
  • 268 views
kailash.potha12
Is it possible to transfer the from Sandbox to Prod Environment or One team to another team..?
dennis.pflug
you can make use of the "Copy to" feature to transfer data pools, data jobs (without data model loads, job alerts and pool parameters and also studio packages and content from one EMS team to another.
To do this you must be member / admin within both EMS teams and I think it is only possible doing it within the same realm. So both teams must be within the same realm like EU-1.
But this only transfers the structrure and logics but not the data that has been extracted from your source systems. In case you want to export / import raw data from one team to another you might can make use of pycelonis but I think in most cases it would make sense to just extract the data again within the other EMS team by using standard extractor.
BR
Dennis
mukesh.gupta11
Level 7
Forum|alt.badge.img+15
Hello Kailash,
Yes you can transfer the data between two EMS instacne using the Data Export and Data push API.
kailash.potha12
Hello Kailash,
Hi @Mukesh Gupta - Do you have any reference document..?
dennis.pflug
Data Push API:
Developer Documentation (celonis.com)
Getting Started (celonis.com)
BR
Dennis
mukesh.gupta11
Level 7
