Count greater than
  • Mar 1, 2023 2:32 PM UTC
  • 5 replies
  • 141 views
rene.szere
Level 3
i am just starting to familiarise myself with Celonis and have started with the Celonis Academy.
Now I have a simple question.
Currently I have this formula: COUNT(DISTINCT "OCH_Cases". "Party_Request_KEY")
I want only values greater than 2 to be displayed.
What should the formula look like then?
Best regards
Rene
  • Mar 2, 2023 6:55 AM UTC
Depends. If you can use it with a component filter, then it will be FILTER COUNT(DISTINCT "OCH_Cases". "Party_Request_KEY") > 2
If you want to use it as a KPI or Dimension like in a OLAP and you can't use a filter, then a CASE WHEN will do
CASE WHEN COUNT(DISTINCT "OCH_Cases". "Party_Request_KEY") > 2 then COUNT(DISTINCT "OCH_Cases". "Party_Request_KEY") else 0 END (or something like that)
HTH
rene.szere
Level 3
  • Level 3
  • Mar 2, 2023 11:26 AM UTC
Thank you for your answer.
Unfortunately, the component filter does not work.
I get the following error:
The aggregation function COUNT cannot be used inside a filter statement. Please check that there are no aggregations used inside filters. Please use a Pull-Up-function instead.
The second formula works very well
  • Mar 2, 2023 11:27 AM UTC
Yes, my bad. In that case you can try the CASE WHEN path, or use PU functions.
rene.szere
Level 3
  • Level 3
  • Mar 2, 2023 12:40 PM UTC
What should the formula look like with the PU function?
With "Case When", all the results are still displayed, but they are, for example, calculated with "0". I want all results where >2 are not displayed.
  • Mar 2, 2023 4:32 PM UTC
Depends a bit on details, your model, what you want to measure... but, I guess:
PU_COUNT_DISTINCT(DOMAIN_TABLE(OCH_CASES._CASE_KEY), "OCH_Cases". "Party_Request_KEY")
BTW with the CASE WHEN this can work for you:
CASE
WHEN
ELSE NULL
