Connect multiple teams to the same extractor and SAP system
  • Sep 26, 2022 12:00 AM UTC
  • 147 views
In the doco, there is a description of how to connect different teams to one extractor but not how to configure this for Linux. Any ideas?
https://docs.celonis.com/en/how-do-i-connect-to-multiple-teams-with-the-same-extractor-.html
  • Sep 26, 2022 10:21 AM UTC
The same extractor and sap system
  • Sep 26, 2022 10:29 PM UTC
Do you mean just adding an uplink entry in the config? application-local.yml?
No need to run a separate extractor service for this?
marco.marso
Level 6
  • Level 6
  • Jul 17, 2023 12:46 PM UTC
not sure whether you still need some help. We faced a similar issue and did not follow the outlined instructions by Celonis but rather went a different approach because of the differences with MS and Linux. Here is a brief summary of our approach:
  1. We duplicated the Extractor Package
  2. We copied the necessary files from the rfc module (.jar and .so)
  3. We adapted the application-local.yaml file accordingly (client id, secret, URL) and other settings e.g. your proxy-settings in the application-local.yaml: Proxy settings for on-prem clients (celonis.com)
  4. We copied a new renamed Service file in the respective directory: How do I set up an on-premise Extractor? (celonis.com) Hence, we opted for the seperate extractor service.
  5. Start the extractor
BR,
Marco
