Automate creating groups and setting permissions using the PyCelonis API?
  • Sep 1, 2022 9:14 AM UTC
  • 173 views
We want to automate the creation of objects in Celonis (e.g. Data Pools, Spaces, Packages) by running a script when new business teams are onboarded to our platform. We do this by using the PyCelonis API.
However, I was wondering if it is also possible to create groups and assign permissions for these groups using PyCelonis.
E.g. for Business Team 'X', we want to create:
  • Data Pool 'X'
  • Space 'X'
  • Packages 'X1', 'X2', 'X3'
  • Group 'X'
  • Set Permissions for group 'X' within the Data Pool and the Space.
I couldn't find anything in the documentation regarding creating groups and setting permissions (only about viewing permissions), so it would be great if anyone knows if this is possible.
Thanks in advance!
  • Sep 1, 2022 11:14 AM UTC
I have reviewed a lot pycelonis and there is nothing to act on the permissions. Nor to create a user or group.
In fact, even checking the "internal" data json of a object, like a studio analysis I never found the least pice of information related to permissions....
But, if you find how... please I want to know too... ;D
  • Sep 13, 2022 12:11 PM UTC
@Guillermo Gost
I've been in contact with Celonis and they informed me that managing permissions via PyCelonis is not possible (and that it is not in the roadmap yet).
  • Sep 13, 2022 12:31 PM UTC
@Guillermo Gost
Thx for the update.
I will check the integration of Celonis with Identity and Access Management systems... depending on what I find, maybe I will request a feature.
Because eventually you will need to integrate Celonis with things like SailPoint, Jumpcloud, etc....
