Aggregation function together with a dimension function input.
  • Apr 13, 2023 2:55 PM UTC
  • 263 views
Sum(CASE WHEN "ActivityTable"."Activity" = 'something'
THEN 1.0 ELSE NULL END) gives me the count when there is an entry "something" in the table.
My challange is following:
I need to count Distinct Case_ID, whenever "something" happens. It can happen more than 1 time for an Case_ID, so i need a PQL statement like:
THEN count (Distinct(Case_ID) ELSE NULL END, which is ofcourse not working like this.
Ideas and solutions are welcome. Thanks a lot
Best answer by Anonymous
Not sure if it is the same but:
COUNT(DISTINCT
CASE WHEN PROCESS EQUALS activity THEN _CASE_KEY
ELSE NULL
works for some similar situations.
HTH
  • Answer
  • Apr 13, 2023 3:34 PM UTC
COUNT(DISTINCT
ELSE NULL
HTH
  • Apr 13, 2023 4:22 PM UTC
Works like a charm...thanks a lot😀
